ASUS MB issue question
Hello,
I recently purchased an ASUS A8N-SLI Premium MB. I have been in the process of pairing this up with a Silverstone Temjin TJ-03 case. This case includes a firewire port in the front of the case. The connector that goes on the motherboard is separated out pin by pin (annoying) rather than being in one, big block (hope that makes sense.) What I attempted to do was to match up the pinout with back-plate firewire port that came with the motherboard. I did this, and when I turned the system on, I got, what looked like a quick flash in that area of the MB, then it started to stink. I immediately turned off the system and unplugged the port. I figured at this point the MB was fried and I was going to have to RMA it, however, when I turned it back on (without the firewire plugged in) it posted just fine, and has been running Prime95 stably for the past 24 hours. I even used the stock ASUS Firewire backplate and tested the 'burned up' firewire port, and it seemed to work okay as well.
My question is, do you think I will have anything to worry about? Have any of you guys seen something similar like this happen? Should I RMA the MB just in case?
~OblivionSHO~
you might want to take a close look at the caps near the firewire port see if they are bubbled... and also the cable those little buggers can catch on fire quickly if you reverse the cable...
but if everything works then no worries
guess thats why its called firewire... ;)
btw
whats the max cpu voltage you got there?
i cant get the bios over 1.55 but the manual says 1.65 :confused:
What might have happened is that one of the wires that goes to the case is burned and you might have destroyed the cases firewire socket.
If the board is working fine then don't RMA it, mobo mfrs get enough working stuff rma'd to them already.
Just consider it a lesson learned, if you really need firewire on the front then either sell the case and get one with the block (coolermaster stacker for example) or get a 5.25 bay with fan control / USB / firewire etc.
