Asus Maximus VI Gene
Etherton
Will Bang for Poof
I have a, potentially stupid, question... :p
Built a gaming rig off a Asus VI Gene and dropped a pair of 780TI KPE's in a Corsair 540 Air case. The KPE's are blocking the furthest PCIe 2.0 4x slot due to their double slot configurations. Could I use a PCI-e riser/extender to "move" a Asus Xonar Essence sound card into that slot - somehow mounting it away from the KPE's?
Any better solutions? I am not going to swap out the mobo at this time...
Thanks everyone!
Thanks everyone!
Yes, as long as
A. You use a PCIe riser with a flexible ribbon cable
...and ...
B. You have a case with the extra slots. In other words a Micro-ATX case with only 4 expansion slots won't work, but a full ATX case with 7 would.
If condition B isn't met, you are going to have to come up with your own solution to mount it.
-edit-
If you are going to do it, you need one of these:
http://www.newegg.com/Product/Product.aspx?Item=9SIA2C50US9991
You will probably have to fold that ribbon cable under the edge of your 2nd card's heatsink fan assembly.
Also, why would you want to plug another sound card into this board? That board already has upgraded onboard audio almost on par with most sound cards.
Thought I read that I needed a 7.1 sound card for the Razer Tiamat to actually get 7.1? No?
Thanks for the help!
Ordered a Asus Phoebus and a 4x PCIE riser but I can not get the sound card recognized in the system. What am I doing wrong? I have the 6 pin connected to the Phoebus.
Pull the riser, blow out the pcie slot, then reseat the riser with even pressure. Double check your 6pin connector and try it again.
Asus Phoebus is DOA. Tested in 2 computers. Amazon rocks and is sending me a replacement though. If this one gives me fits I will be exchanging for another manufacturer.
Dude just get a creative zx or zxr, something like a sennheiser 558 or 598, 600 or 650 and call it a day.
After many years of trying over 70 headphones, that is the easiest pc setup that sounds good for anything.
Just listed my Tiamats for sale. Looking at the Sen 598s and a Creative Z.
Ended up buying the Sennheiser 598s and a Aune T1 Dac/Amp combo. Looking through all the different tubes now...
OMG. The difference! This is my first "real" computer audio setup... :D
Suck it Razer!
