Will I be able to run 2 x 290 in crossfire by putting the first card into slot 1 (red) and 2nd card into slot 3 or 4 (red)? Reason I ask is because the manual states that if you run two cards then they must be inserted into slot 1 red, and slot 2B (black)
With the way my watercooling bridge is set up I cannot put a card into slot 2B, there simply isnt an option for that. So I am curious if I will have any issues with my plan? Otherwise I will have to get something like a Maximus Hero VII.
http://www.nexthardware.com/repository/recensioni/823/immagini/MAximus-VI-Extreme-Slot-PCIE.jpg
Thanks
Thanks
