After running Realbench Stress Test for just 15 minutes according to Core Temp, Idle Min was 26C and Max temp was 73C. The other 3 cores were within 2 or 3 degrees.
My 7700K is at 4.9Ghz and while testing Core Temp read 1.3644 volts. Water cooled by Raystorm Pro, EX CE 420 radiator, D5 set on 3.5 and Photon 170 res. Nothing else in the loop. The 7700k is re-lidded with CL Liquid Ultra. A 47 degree C difference between Low and Max is a bit high yes? I see similar spikes simply opening up web pages. Is this normal???
