Asus Maximus IX Code CPU Speed Fan Error
Guille_arg
Good night!! I have recently bought this new MOBO z270 with an i5 7600k... I have installed a Corsair h80i.
Well the problem I have is when I turn on the PC, shows me "CPU Speed Fan Error" on the boot.
So I enter on the BIOS and check the fan speed and show 800 rpm, I ve select "Ignore" on the Fan config to avoid the speed fan and the save and restart the computer but I have the same error.
I was able to enter on Windows from Boots option and selected the Windows storage. On the AI Suite shows 0 rpm of CPU FAN.
I have tryied a lot of things, connected on other fans pins, update the Bios and does not work.
I don't know what it is.
Thanks for your help.
This may sound like an simple suggestion, but did you take off your side panel and see if you felt any air flow coming from the fans and see them spinning?
Try it first in the bios, and if they are running proceed to windows and if they are still running you will know that AI suite simply has some kind of error.
That said, if the fans are not running when you boot up windows you should proceed to shutoff your computer so it doesn't overheat.
Not sure about that particular bios error though.
I don't have temperture problem and the fans run perfectly, it's a bug of the mobo or I don't know what it is
