boostdemon
- Nov 12, 2004
I'm having a terrible time getting this setup to work. I'm using an Asus m5a97 R2.0 board with 4x 1TB WD Red drives for storage and 1 Kingston HyperX 120gig SSD for Win7 64 Home Premium. The thought is to have the SSD by itself for the OS and the 4 1TB drives in a RAID10 configuration totaling 2TB of semi redundant data storage thats still fast enough to do photo/video editing. So far i have not been able to get windows to even begin installing.
Drive setup:
Theres 6 ports on the board, i have them setup in a CFI Case with a hot-swap drive array. Ports 1-4 are on one controller and 5-6 are on another.
Controller 1-4 : 1TB WD Red drives
Controller 5-6 : HP BR Optical in #5, Kingston 120gb SSD #6
Mobo setup:
I've gone into the southbridge config and set the SATA controllers to RAID mode using the Legacy ROM option (i havent figured out how to setup RAID with the UEFI mode). I have left it with RAID for both controllers since switching 1-4 to RAID leaves only RAID and IDE as options for 5-6.
*I have tried in IDE for 5-6 as well with no luck
*I have tried with another 1TB WD Black drive instead of the SSD and also failed
Here's what happens:
So i switched the controllers back to default AHCI mode and boot from CD, deleted all the partitions i could find so it was unallocated space with no prior OS data. Rebooted and switched back to RAID, lost a drive in the array during this process and started that over. Installed again and got the following error:
*sigh*
So, what am i missing?
It's been a while since i've built a PC (for reasons exactly like this) and I have no experience with using RAID and a single drive together, no clue what UEFI is other than its how you get win7 to use a 2+TB drive as the boot drive (shouldn't be an issue for me)... I'm totally expecting someone to see this and say "Duh moron, you cant do ___ with ___."
Drive setup:
Mobo setup:
- Set both controllers to RAID mode in the SB Config
- configured the 4 1TB drives as RAID10 in the Legacy ROM
- Boot from win7 64bit Home Premium DVD and load Asus RAID driver: ahcix64s.inf
- Select Custom Install and chose Disc6 (SSD) and chose "New" (creates partitions) Hit next...
- Win7 install starts and fails with the following error:
to which i throw something and go back to the "install now" screen at the beginningWindows could not format a partition on Disc6. The error occured while prepairing the partition selected for installation. Error code: 0x80070057 - Then when i try to start back over it errors saying:
to which i hit continue exactly 12 times to the error before it comes up... uh. ok.The drive is not ready for use: It's door may be open. Please check drive \Device\Harddrive6\DR6 - try to delete the partition to start over since it shat the bed and i get:
Failed to delete the selected partition. Error 0x80070015
Windows cannot be installed to this disk. This computers hardware may not support booting to this disk. Ensure that the disk's controller is enabled in the computers bios menu.
*sigh*
