I have typically had mixed results with G.Skill memory. That's typically why I've stuck with Corsair more often than not in my own systems. The stuff just works. We've also had pretty good success with the Patriot memory. I've also enjoyed working with OCZ RAM in the past.
You shouldn't have to switch to an Intel board. I've never had any problems with any of the recent Socket AM2+/AM3 stuff. Have yuo set your RAM timings manually? If not try matching them to the specifications shown on the label. Some boards just don't play nice with the SPD values of some modules.
I set the timings all except the command rate which you can't change. I'll have to wait till the morning to see if it causes problems, seems like it does it when it hasn't warmed up.
edit: OH NOES! Just ran a memtest. 1376 errors in 40 seconds.
Don't set timings, let the bios automatically configure the default timings and try it again.
Asking memory manufacturers (especially the ones you get on sale most often) to have their sticks run at advertised timings is about as practical as shoving toothpaste back into the tube.
Running F3-10666CL8D-4GBRM G.Skill ram with this board here. No overclock, no manually entered timings, nothing. Stuck it in the last 2 banks (for unganged mode) and left everything else alone. No problems.
Well I got my new ram but I still have errors but not nearly as many. I got over a 1000 a min before now I get only 1 a min but why am I getting errors? is it the mobo? cpu? or I just get more bad ram?
Hrm. I'm just going to run through my usual questions:
Are all the slots full?
Did you blow dust out of the slots before putting the new sticks in?
Did you try different slots instead of the ones you had sticks in previously?
Have you run memtest with only one stick in the system at a time?
You could be looking at a bad slot situation. Test one stick in each slot until you have a combination in which one stick DOES NOT result in errors when installed in a specific slot. Install the other sticks, one at a time, in that same slot. If they result in errors, could be bad stick. If they don't result in errors but do when you put them in any other slot, could be a bad slot. There was a post on here a while back where memory errors would crop up if the water cooling bracket for a kit was overtightened. If you're not using a standard clamp that goes onto the motherboard's CPU sink cage, that's another possibility.
Most of the memory problems with this board seem to stem from the fact that it is locked in at 1T command rate in the BIOS. I have never had a problem with mine, but why they don't provide such a simple option to change the command rate in BIOS is beyond me.
Well I got more problems now, I noticed that my ram is only running in single channel so I went to put both sticks in the black spots, doesn't post, I tried both blue slots doesn't post, I then tried b1 and b2 doesn't post, it will only post in a1 and a2. I tried clearing the cmos each time I changed the ram, still didn't work. I don't know why. Any clues?
Edit: Im using two 2gb kingston sticks that are listed as compatible on the asus website.
Have you tried different RAM? Just to see what it does. Make sure your voltages are dialed in within specifications if you haven't already. Other than that, I'd say you've probably got a bad board.
Or you could have a short from the case itself. Take it out of the case and run the motherboard on a desk. Try to duplicate your issues.
If I leave it in the a1 and a2 slots I don't get this problem, i can move/slightly bump the case with out a bsod. It only happens when either both the black or both the blue slots are filled. I'm just going to send it back tomorrow for a replacement or a refund and I will pick a different mobo.
Is this in the case or out of it?
Because the fact that you are getting BSODs when you move the case.......
It could be the case itself just being *enough* out of spec for it to cause an intermittent short. I my M4A mobo in a temporary case when I first got it and had static discharge issues (i'd just touch the metal chassis and the system would reboot)... bought a proper case for it, problem went away.
