ASUS M4A78 PLUS sata/raid drivers for XP
chisaipete
I'm trying to install XP SP3 on this machine, but need it's SATA/RAID drivers for the slipstream. Anyone know where to get them? I think the disk only comes with the Vista 32 drivers.
Well you can find out what version SATA/RAID drivers its using, most likely Intel Matrix Storage and then download the drivers from Intel, extract the installation files and you'll only need the the driver files with the yellow color on it icon (sorry forgot the extension)
Next up install vlite or nlite and make a copy of the XP or Vista windows disc files on a place on your hard drive and then slipstream the driver files into the copied copies of XP or Vista OS files on your hdd and then burn the new slipstreamed os to a disc choosing the bootable option before you finalise the slipstreaming process.
Load up disc in before windows boot and their you go, no more BSOD's, can't install errors or error log pop ups.
Sorry but I don't know the specific SATA/RAID drivers your motherboard uses.
