ASUS M3N78-VM bizarre LAN behavior
mdahu
My HTPC setup
Above motherboard with nVidia 8200 chipset
AMD athlon x2 5400+
4g RAM
Vista home premium 32bits
500 gb Samsung
Hybrid SLI setup with EVGA 9800gt
My HTPC is connected via ethernet to a wireless router, which in turn is connected to my cable modem. I have 3 other computers connected via wireless to the same router and a vonage telephone adaptor is hard wired to the router.
Intermittently over the last 2-3 days, I am losing internet access to my HTPC, and the network icon on my task bar says "local only". This can happen within 5 minutes of starting the computer, or 4 hours. Before it happens, the setup is working flawlessly. Once it happens, I am no longer able to disable my network adaptor, renew IP, uninstall the driver....etc. The problem disappears when I restart the system.
When the LAN hangs up like this, my hardwired vonage, and my wireless internet access is working flawlessly. So I know the problem is in the HTPC.
Before the system hangs up, I am able to easily disable/enable, renew/release IP, uninstall/reinstall drivers without difficulty.
Does this sound like a hardware problem, or a software/driver problem? I am confused.
I recently installed a windows update package related to TV pack. Could that be it? Also, I changed one of my laptops OS to windows 7 that connects wirelessly to my router. That couldn't be part of the problem? could it?
I appreciate any guidance on the matter.
