asianguy80
- Oct 22, 2003
Hi all,
My current setup:
Asus M3A78-EM
AMD 5050e
2GB G.Skill DDR2-800 (red heatspreaders)
XFX 4650
WD3200AAKS
Corsair HX520
Watercooled and housed in a Coolermaster Stacker 830
I currently have the setup above. I had to reinstall WinXP to get eSATA working. I did a slipstreamed copy of WinXP with the AHCI/eSATA drivers integrated into the install and all is fine on that above mentioned PC.
Now my problem is that I'm building a similar setup for a work PC for myself and this is where my problems start to come in. Here is the setup:
New build:
Asus M3A78-EM
AMD Athlon II X2 240 cooled by Scythe Shuriken
eVGA 7900GS
WD3200AAKS
Corsair HX620
Aircooled and housed in a Silverstone SG01
I couldn't wait for the 240e cpu's to come out because my laptop at work is dying out on me so I had to pick up parts asap and get this rolling but now I'm hitting a stump. I recall that when I was installing the AHCI drivers the first time around that you must enable the AHCI in the bios in order for the install to detect the setting and then install the correct driver for it. Now I've created a slipstreamed version of my WinXP Pro with all the updates to 10-19, WMP11 + updates, and the AHCI/eSATA driver slipstreamed into the CD and done all the custom setup with nLite.
Each time I try to install with AHCI enabled I get the BSOD that says I need to CHKDSK /F on the hard drive blah blah. I've tried installing on SATA mode which is basically IDE and it installs fine. I've googled it and it says that the M3A78-EM boards have a thing where the AHCI corrupts the windows install but my home PC works fine so I'm wary of the generality of that statement. The mobo is the same Rev 1.03G and I've updated the BIOS on the 240 board to 1902 so that it will support the AM3 cpu.
I'm at my wits end as I need the eSATA hot swapable feature because I've got an MX-100 case with all my work backed up and I'd prefer to use the eSATA over USB.
If anyone can help that would be excellent. Thanks a bunch!
My current setup:
Asus M3A78-EM
AMD 5050e
XFX 4650
WD3200AAKS
Corsair HX520
New build:
Asus M3A78-EM
eVGA 7900GS
WD3200AAKS
Corsair HX620
