Asus M2NPV-VM SPDIF
theTIK
They way I understand it using the SPDIF on a sound card would be exactly the same thing as using SPDIF on a motherboard it is just a passthrough so it doesn't matter. The Asus M2NPV-VM doesn't come with one onboard, but the menual says there is a module you can buy that has an SPDIF out that you plug into a little hub on the motherboard and place the module on the back of the case. Does anyone know where I can buy this?
Is that the basic one that only had the one connector? Do you have a picture of the bracket?
I think I have one of those kicking around somewhere, Let me see if I can find it
Ok the one I have only has the top connector not the optical, The M2NPV only looks like it has the one connector anyways. I think it was off some other asus board I got a while ago like a p5ld2 or something.
I will take a pic tonight
Hey I think it looks exactly like the one you need and it does have the optical, I did not notice it until I opened it for pictures. If you want PM me we can work something out
