Asus M2NPV-VM question
mr saturn
Okay, I've finally decided on a SFF build (sorry to those who have been reading my threads and witnessed my indecision). I'm going to use the Antec Minuet 300 Slimline, and put an Asus M2NPV-VM in it. The ONLY thing left that's holding me back is trying to figure out if the multimedia expansion card will fit in the "half-height" pci slots the Antec Minuet has. Can anyone give me a definitive answer on this?
If it won't work, do you think a minor case mod would be able to get those plugs somewhere accessible?
Thanks yet again.
All youde have to do is find a drill bit a little bit larger than those plugs and align the holes, and glue it on, or screw it onto the chassis. Full PCi slots dont fit in half height slots.
Yeah, I figured as much. I think I might try to put it in the mesh above the I/O panel.
