Asus m2npv-vm not seeing videocard! please help!
mooky
Hello there,
specs
Asus M2npv-vm
geforce 8800 gts
Just a few days ago the screen on my computer would start flickering and then eventually just totally freeze. I took out the video card and it did seem a little loose in the PCI slot. I put it back in and fired up my computer. Now it doesnt see any video at all. I put 3 other PCI cards in to test to see wheather it was the card or not but i think it definatley has something to do with that PCI slot. All the cards still receive power from the PCI slot it just doesnt show on the monitor, blank monitor.
Please help me, what can I do????
I would GREATLY APPRECIATE whoever can help me. Thanks in advance
It does sound like MB.
To be sure check your monitor and power supply.
Last thing to try is to disconnect all unnecessary equipment and reset the bios and try to boot.
it has onboard video - disable it in the bios if you are using an external board. Make sure you're plugging the monitor into the right connector.
I got the videocard working now, but it is still messed up.
It will work anywhere from 5 minutes - 24 hours but then the screen will randomly flicker and freeze the computer. any suggestions now?
