Doing a build for a friend with the following spec
ASUS M2N32-SLI Deluxe
AMD FX62
G-Skill 2GB PC8000
WD Raptor 150
2xBFG 7900 GTX OC 512
Did a barebones install and on initial boot got 3 beeps (1 long, 2 short)
Hit the web abd this suggests it a gfx card prob. Have tried both cards seperatly with the same result... Wondering whether its RAM compatabilty.
Does any1 have the same build/any idea what to try.
AMD FX62
G-Skill 2GB PC8000
WD Raptor 150
