Asus M2N-SLIDeluxe - BIOS question
cwolf78
I have an HTPC with an Asus M2N-SLIDeluxe mobo in it ... it works great... there is just one 'cosmetic' thing that bugs me. It is on the bootup screen .... it says 'Detect drives done, no any found' .... now, besides the bad grammar it just bugs me that it says this... I must have a setting somewhere wrong... like it is looking for a special drive or type of drive that I do not have in it. My HD is SATA and my optical drives are one each... SATA and IDE. There is no floppy drive at all... :confused:
I think you are getting the "no detect" message for the Jmicron RAID controller. You can just disable that controller in the Advanced, chipset section to get rid of the message. Most of us don't bother using the Jmicron controller for RAID anyway. I think they chose that chip because it also includes the ability to run the single IDE port (though disabling the Jmicron RAID controller won't mess with the IDE port).
I literally disable all of the things I don't use in the chipset setup like the Jmicron controller, the serial port, the parallel port, and the second NIC. I figure it reduces the number of resources needed and speeds the boot time.
