I have an intel version based on the same chipset (AMD 690G) with the Abit F-I90HD which apart from some USB related BSODS has worked solid.
I just built an amd version based on the new asus m2a-vm hdmi motherboard, X2 3800+, Kingston KVR667D2N5/1g x 2.
On the intel version I get an Vista performance rating of 3.7 (with an E4300 at stock speed) and it can playback X2641080p without a problem. The Asus is another ballgame, when installing Vista it did only detect a standard VGA card, and I couldn't install Catalyst 7.4.
I flashed the Bios to 0701, after that I could install Catalyst, but I still can't get the performance rating over 1.0. The video card is reported as x1200 (should be x1250) I have tried both 7.3 and 7.4, I have confirmed that memory is in dual channel mode and I have allocated 256 MB to vram.
I get tearing and choppy video playback.
Does anyone have any suggestions where I go from here?
