Asus K8V RAID1 Array failure, Help please.
I have the following configuration nothing overclocked:
Asus K8V
2x512 Corsair ram
primary master 40g ide
promise raid controller 2xWD120JB connected with Highpoint Rockethead ATA->SATA adapters
When i create the array it is fine, however after a few shut downs, or a power interuption the RAID1 array is flagged as critical and must rebuild. Sometimes the 2nd drive in the array isnt detected as part of the array, even tho it is listed as connected to it.
I tested the hdds using wd's utilities in both ATA and SATA mode, there are no problems.
Any suggestions? I am currently doing more diagnostics I will keep the results posted.
I havent ever worked with RAID 1 , but I currently have a RAID 0 setup. Here's my take..
You have to install the raid drivers from a floppy disk when you install Windows, and you have to install addition windows raid drivers AFTER windows is installed. Check www.viaarena.com for the latest releases.'
EDIT: Oh yeah, if you overclock on this motherboard - expect frequent hard drive data corruption and RAIDs failing.
