Asus K8N, crashes
rgraze911
I think I've narrowed my problem down to the motherboard or CPU. I put the system together and right away had a problem trying to turn it on. I would hit the power switch and it would just flash, not turn on, this would happen for a few times. So I installed windows with no problem, I installed the video and sound card no problem, I installed BF2 no problem, Then I had problems installing BF2 SF. I checked the power supply, the 3 volt was fluctuating wildly and the 12volt line only put out 11.1 volts. So I replaced the PSU and now the comp turns on like it should. But now its unstable, When starting bf2 it would crash and give a horibly sound and the colors would be slightly off. I went ahead and removed sound card and activated onboard sound, no change, remove video card and replaced with another, no change, replaced memory, no change, ran diagnostics on hard drive, all ok. So what am I looking at? How do I tell if its a cpu problem or motherboard problem?
Need more information concerning your system configuration. I.E. make and model of all your components.
Just as a side note, paragraphs are your friend! ;)
Yes but english was not....
Well, its an ASUS K8N, AMD64 socket 754, clawhammer. NVIDA 6600gt, Creative Audigy 2, WD80gig. 600watt PSU. I think that about covers it.
Its an ULTRA 600w with a window! I really dont think its a PSU issue, I've had this in another comp.
Just need to know if you think its a MBoard or CPU problem. I also just ran memtest with no errors and it has latest drivers.
