Asus Impact, 4770K - 'Per core' multipliers not working
xinux
Running my cpu at the 'sync all cores' setting, i can boot at 4.5ghz.
However, when I try to use the 'per core' multiplier setting, I'm getting problems.
45, 45, 45, 45 - All is fine
45, 46, 45, 45 - Clock stops working
What I mean with not working, is that it doesn't seem to get applied.
Booting windows and checking cpu-z (during a benchmark), all cores go back to around 3.7-3.9ghz, where it usually runs with the default 'boost' settings.
The clocks are reflected in the performance (score gets lower), so it's not cpu-z showing the wrong values.
Simply put, it seems like the clock settings go back to default when I use varying multipliers on my cores.
The system is stable, and the temperatures fine. Voltage at 1.3, BCLK 100.
Anyone got a clue?
My post on overclock.net
