Hi
I have an Asus G73JH. When i bought the notebook (it is used) the LAN port didn't work. I diassembled the nb and check for the cables, the problem was that the LAN connector was not properly connected. Then i reassemble, then LAN work ok, but now with problem on the display.
The screen is flickering from the half to botton like this
And have yellow marks (in white pixels i see them) like this
When i connect via HDMI the image is clear and no problems, is not the videocard. So i assume that i broke the lcd flex or the lcd display. I don't have spares of these to check where is the problem... any suggestions to the right direction?. This problem was typical from the flex or the lcd display?. In my country is not easy and not cheap to get the replacements... that's why i ask.
Thanks.
Thanks.
