ASUS Front Panel Audio Issue
Dedpoet
Sorry to repost this from the Audio section, but 48 hours without a reply and this is as much a motherboard issue as an audio one.
I'm having a problem connecting the front audio panel connectors on an old version Coolermaster Praetorian to an ASUS M4A78 Plus motherboard.
According to the motherboard manual, the header can act as HD Audio or AC97, depending on how you toggle it in the BIOS. This is how it describes the pinouts. The "O" is the spot without a pin, where it would key if this were a solid connector. Yes, the manual shows "PORT1 L" twice. I assume the bottom one is "PORT2 L":
Code:
HD Audio:
PORT1 L     XX  GND
PORT1 R     XX  PRESENCE#
PORT2 R     XX  SENSE1_RETUR
SENSE_SEND  XO
PORT1 L     XX  SENSE2_RETUR
AC97:
MIC2        XX  AGND
MICPWR      XX  NC
LINE OUT_R  XX  NC
NC          XO
LINE OUT_L  XX  NC
Unfortunately my case connectors are not labeled either way. They are:
Code:
Ground
MIC Power
MIC In
L OUT
L RET
R OUT
R RET
Ground
Google searches have led to 404'd pages, unanswered posts, or answers that don't make any sense. Does anyone know which pins should go to which connectors, and whether I should be using AC97 or HD Audio in the BIOS? Thanks!
Issue is resolved, with help from Nicholas at ASUS. Here's the solution for posterity. With AC97 selected in the BIOS:
Code:
MIC IN XX  GROUND
MICPWR XX  GROUND
R OUT  XX  R RET
NC     XO
L OUT  XX  L RET
