Asus Formula: Can't boot sata, need advice.
Betaboy1983
I have an Asus Formula motherboard, and running Vista 64 on an SATA AHCI 250 gig HDD.
Well, I was installing new video card drivers and my son managed to reset my computer when I got up for 2 seconds to get a soda. Upon reset my it was as though my CMOS got cleared as I had to enter the bios and re-do the settings. After post I get the message:
"Reboot and select a proper boot device"
Well, the bios detects the HDD in AHCI mode (as well as IDE ehanced mode) and lets me select it as my first boot priority, but every time I try to boot into windows I get the same message. I booted from the Windows disc and my sata DVD drive works perfectly fine, and Windows doesn't see any versions installed for repairing purposing.
After much screwing around plugging in my HDD in different sata ports (I normally have it on port 1), I took out my wife's identical sata Windows drive and put it in my computer and it does exactly the same thing with her drive.. What is going on? I would imagine if the sata controller on the motherboard fried it wouldn't even detect the drives, let alone the DVD drive works.
Any ideas? Thanks so much for any info.
Check to make sure you are booting to the proper device first in the boot device priority list in the bios. If you have any USB drives or CD's, remove them and try to boot again.
