ASUS EAX1800XT Top????
MaxOut313
I'm looking at getting one of these with a crossfire mobo, but im wondering whats the difference from the X1800XT besides cooling and being overclocked. Is there better memory modules on it or are they the same? Im taking off the cooling solution anyway and putting on water cooling kit for cooling...
common, doesnt anyone know if the EAX1800XT TOP/2DHTV/ 512M is using faster ddr modules??
I'd say it is a faster X1800XT, for sure. Look at the clocks and memory.
Model
Graphics Engine
RADEON X1800XT
Video Memory
512MB DDR3
Engine Clock
700MHz
Memory Clock
1.6GHz (800MHz DDR3)
Memory Interface
256-bit
Max. Resolution
2048 X 1536
Bus Standard
16-lane PCI Express
VGA Output
Standard 15-pin VGA (per DVI To VGA Adapter)
HDTV Output
S-Video to HDTV
TV Output
S-Video to Composite
Video Input
DVI Output
DVI-I
Dual DVI Output
Yes
Dual VGA Output
Yes
ASUS Cooling technology
Yes
Adaptor/Cable Bundled
DVI to VGA adapter;
9 Pin S-Video to HDTV cable;
9 Pin VIVO cable
Svideo Cable;
RCA COMPOSITE CABLE;
ATX POWER CABLE
AC POWER CORD
ADAPTER 80W
Software Bundled
KINGKONG FULL VERSION DVD
Asus XitePad,
GamePack-(, Second Sight, Chaos League, POWERDROME)
SNOWBLIND,
Joint Operations,
Xpand Rally,
ASUS DVD XP,
Power Director 3,
Media Show
ASUS Utilities & Driver,
see i've read that. the thing is im not sure if they are just said 800Mhz DDR3 for marketing or is it acutally a new module with lower ns. It could just be the same modules overclocked...
It's the same module overclocked, keep in mind this card needs to be plugged into a wall socket and not the PCIe power connector on a power supply.
Yea i noticed that. When they gonna be avaible? I heard next week. I looked around to see if anything site gives a date but nothing.
If I may give my opinion...
That thing is not worth it. Anything that requires additional external power is in my opinion a waste of money. I would say get yourself a "regular" X1800XT and overclock the core/memory yourself.
