The fan on my EAH6670 has been intermittently making loud noises which is becoming more frequent. I'm guessing it could be the bearing so I want to replace it. Unfortunately I can't seem to find a replacement fan. The closest one I found is this
http://www.amazon.com/Evercool-80mm...eywords=80mm+VGA+Card+Replacement+Fan+4+screw
but this is three screws as opposed to mine which has four. Does anyone know of any other options? Thanks.
