Asus EAH4670/DI/1GD3
Simmonz
I am thinking of buying the Asus 4670 1GB for a spare PC next pay cheque but I can't find any power requirements for it. The PSU in the spare PC is a 500 Watt Seasonic 500 Watt with 33 amps on the +12V rail. it has two six pin connectors and oddly enough one eight pin connector. Does anybody know what the power requirements are for this card ? i checked Asus' site but found nothing.
I don't know anything about the power requirements either and if it's not specified in the Asus site, then I don't know what to recommend, except maybe a search in forums for someone that has the same card.
Either way, 1 GB on a card like the HD 4670, is really not worth it. You should be looking at the regular model instead, which should be cheaper too.
Yeah after checking the 512MB model out I will go for that. The Memory clock is 400 MHz faster than the 1GB model and is $22 cheaper. I will check around for the power requirements. Worst case I will buy a new PSU if I can afford it.
The 4670 is pretty good in terms of power consumption.. it doesn't even need external power.
As long as the PSU you have is of good quality, I see no reason as to why it would not work .
