ASUS E35M1-M Pro driver problems with Windows Home Server 2011
Nerva
I have built a home server using the ASUS E35M1-M Pro motherboard, that runs the AMD E-350 APU. It is running Windows Home Server 2011, and although ASUS has no drivers for WHS2011 or Server 2008 R2, it did have drivers for Windows 7 64-bit, and I was able to directly run the AMD install. However, I am getting sound and graphics errors when I try to playback video, and the desktop graphics seem unaccelerated, suggesting that the drivers are not working properly.
Since WHS2011 is essentially Server 2008 R2, that has been around for a while now, I am wondering if anyone has any experience getting one of these AMD E-350 based boards running.
Looks like the driver on the Asus support page is dated Jan-2011, whereas the AMD site has a spanking new driver released just yesterday. I'd give a try at getting the driver directly from AMD, but be prepared to roll it back if flaky-ness ensues. I have to do this with Dell servers and the like all the time for nic, video, etc.
Curious though, why using the whs for a display unit? Not saying you can't, but really it's meant to be a server, to stream your junk to a display unit. That being said, how much memory do you have installed and how much is available to be shared with the GPU? You might want to get a good measurement of what your ambient cpu/memory loads are and monitor them when you start say a video playback. I use my whs11 just to stream, but its in a full box with a quad-core. If it comes down to it, maybe I can do a baseline resource usage for you for comparison.
Yeah I just installed the new drivers last night. I think the server graphics work correctly now but I have yet to get the audio working so it is hard to know for sure.
The server has a monitor connected in front of my exercise machine, so it functions like a basic TV set -- I don't use it for anything serious.
It has 4GB of RAM I believe. I have yet to see it use more than 2GB in task manager.
It is more than a speed issue -- I was getting DirectX errors when I would try to use Media Player Classic. I have not tried it yet with the new graphics drivers.
Yes, I just installed the very latest (Dec 16th) R267 drivers, and there's still no sound. I did find someone else with the same problem on a different forum -- he said he's not getting sound from the back panel or the SPDIF, but the HDMI does work.
The graphics play Blu-Ray smoothly, however. If I could just get the sound working, it will be a great machine.
You won't get sound in WHS as the audio service has been disabled. You have to remember that WHS is optimized to do specific things, not to be used like Windows XP Media Center Edition.
You can try enabling 'Windows Audio' through the services console. If it won't enable itself, you won't have sound.
Windows Audio is already enabled.
The other guy having problems was running Windows 7.
I have noticed that if I FIRST login locally and configure it for speakers rather than headphones, I will get a tiny amount of sound from the speakers. Turning all the volume controls all the way up makes it about as loud as a pair of headphones.
