Hi all, I have an Asus DirectCU Radeon 6850 and it's making quite a bit of noise at idle. It's not a "smooth" fan noise, either.. there's a slight (very slight) buzz to it. Is there any way to determine if this is normal? Just trying to investigate before I contact asus.
I have verified that the fans are running at their normal speed (22-23% at idle, not sure what that translates to in terms of RPM).
thanks
beadle
thanks
beadle
