Hello.
First read,please:
http://www.reddit.com/r/pcmasterrace/comments/4m16gr/power_supply_surges_detected/
Somebody said,scroll down :""The surge protection feature on Asus boards will trigger in the event of a suddenly power cut. Literally anything could trigger it, from a sudden power loss to accidentally flicking your PSU switch.
The more pressing issue is that your computer keeps suddenly restarting. That isn't normal, and usually points to one of two problems: either your PSU is not delivering stable current, or your motherboard's VRMs are unstable."
So he mean that suddenly power cut,power loss can make pc restart too with anti surge warning or he mean only full shutdown pc and then manually boot up with anti surge warning?
I ask because he said next:"The more pressing issue is that your computer keeps suddenly restarting. That isn't normal, and usually points to one of two problems: either your PSU is not delivering stable current, or your motherboard's VRMs are unstable."
He said now about auto restarts with anti surge, that they are most caused by faulty mobo or psu.
Thank you for explanation
First read,please:
