Asus AI Suite Weirdness
Sovereign
Every time I boot my computer (resume from hibernate is fine) I get this on the top of my screen.
I know it's AI Suite because if I close the app from the tray, the gray box disappears.
Anyone else have it, and is there anything I can do to get rid of it?
yes I have that too. AI Suite is just plain buggy and often it will turn into a memory leak as well.
You just have to open the app from the tray or close it.
ai suites been broken since day one. i'm not sure if asus even bothers to try fixing it either. all the problems i have with the original ai suite thats on my asus m2n-sli deluxe board still exist in the newest versions of ai suite.
ai suite gave me a shitty overclock, not that it was low (it wasn't, gave me 4.8Ghz) but it was unstable and crashed.
AI Suite had potential but it was broken from the get go as others have said. I ended up not using it.
You managed 5GHz on your own manually though? AI Suite also gave me 4.8GHz but it seems stable so far. What did you have to tweak manually from the auto overclock?
My AI Suite is really buggy as well. I like the easy overclock ability though.
