ASUS A8V, USB header???
jhego
I'm wondering, if the ASUS A8V Deluxe have an internal USB header? I would like to connect the Matrix Orbital without running a USB cable to the back of the ports. I would like to connect it to my motherboard. If this motherboard does have a USB header, could you point it to where it exactly is located? Thanks.
It does have a header or two on the very bottom of the mobo (ala firewire header, typical headers for the pwr switch, leds, etc). The manual gives the pinouts and locations.
they're at the very bottom of the board, at the back of the last PCI slot. 4 headers are provided.
