Asus A8V overclocking
Criton
Anyone out there have this board and done any o/cing yet, so far all i can get stable is 220x10.5 but there is no option to lock the agp/pci bus. I feel like there is so much more headroom but just the lack of options to do it, temps are idle at 45c. anyone else feel like there is a serious lack of enthusiasts boards available for AMD ppl??
Criton
i have the same board/processor.
so far i have obtained a 216x11 without any problems. idle is around 36 and load is 45.
i put the core on 1.525.
i have a slk-948u HSF so i know i could go alot further. i havent tried any higher then the 216x11 because i havent had the time to play around with it. i still have my 9700 pro so i dont see the point in going any higher till i get my x800xt pe which should be in on 07/15/04. keep me posted on your overclock.
any chance asus will unlock the multipliers for 12+?
or is this not even possible?
the mutiplier is set by the cpu not the mobo.
check your email.
Criton
check your email.
Criton
unless its a FX-53 then you should be able to set it by BIOS correct?
thephenom said:
That's crappy VIA for you.
I thought it was the board makers who cant get it right :confused:
also when the hell is that MSI socket 939 mobo out?
