Asus A8V. I give up
IceWindus
Even doing this for a living, sometimes I just have to admit defeat and take my losses. I"ve spent the last 4 days trying to get my Athlon 64 setup working with Asus A8V but to not a single stroke of luck. Below follows my sad journey back into the AMD world....
After the usuall ripping out old equipment and setting up the new stuff I booted the machine. All seemed good. I changed some stuff in the BIOS turning off uneccassary junk. Rebooted and threw in the XP Pro SP1 disc.
First problem I ran into is that I apparantly didn't have the correct VIA drivers on my floppy. So I took the ASUS CDROM and ran the Makedisk utility and tried again. This time it took and started the Win XP install.
Ok, after full format and intially loading, reboot and off I went into the XP installing screen. All of a sudden, reboot. Mkay....trying again.
Back into loading screen and then a blue screen. WTF. Try again and blue screen repeteadly. Take out old SATA cables and install new ones and wipe drive and try again. Crashes during installing of intial files. WTF????
Rewipe drive and try AGAIN. NOw it gets through the intial Windows installing and I get to my CD Code typing and then starts loading the drivers. And then outa NOWWHERE the machine starts bitching about drivers not being Windows certified? WTF???? I have NEVER seen XP do this during intial install.
Pissed off, I ripped out the corsair ram and threw in a single stick of Corsair value RAM 256 meg. Rewiped drives and tried again. This time the install went without a hitch and I finally had windows. I started doing Windows updates and all my drivers. I popped out the Corsair Value RAM and put the corsair XMS back in and increased the VDIMM to 2.8v.
Machine booted and I continued loading stuff until during a reboot, spontanous crash. ARRRRRRGHHH!!! Reboot again and went into windows. Started Audigy 2 install but 95% through the install it crashed saying " Catostrophic error blah blah blah" Rebooted and the sound worked. Then during Windows updates, farking BSOD!!!!!!!
Furious and nearly out of energy, I ripped out the SATA drivers and threw in my orginal Western Digital IDE drives and started all over and reinstalled everything.
This time I was able to get a operating Windows XP enviroment, but soon afterwards, Here comes the Windows and IE crashes!!!!
Getting really pissed off, I tried 4.10e VIA SATA drivers, reinstalled the SATA Barracudas and tried again. This time I actually got into Windows enviroment but not long after, my Windows Updates crashed out, IE continued to flake out and eventually system locks. *BLEEEEEEEEEEEEP!!!!!*
So, then I ripped out my Corsair XMS 3700 and put in 512 Corsair value 32000 RAM and then did both PATA and SATA drive installations and fresh XP installs. BOTH times Windows errored out or locked up, or both.
Having enough, I'm sadly shipping all my stuff back to newegg and zipzoom fly. My Intel setup has been rebuilt and THANK GOD, its working just as stable as it was.
Sorry to say, I don't think i'll ever be giving VIA another chance, im dissapointed in ASUS's quality drop after 2 great mobo's from them in the past and I'll see how the AMD world is doing a year from now. Until then, thanks but no thanks.
okay your journal doesn't mention this but did you flash the bios? thats what you should of done 1st thing off, also the non certified drivers thing doesn't mean shit just ignore it
oh yea dont turn anything in the bios off.. at all.. your doing initial setup not tweaking
and dont think im trying to be like stupid i know you know your shit, im just pointing out the obvious shit because.. thats usualy what people who know what there doing overlook
BIOS was 1008 version and when I did the SATA setup the second time around, the BIOS was cleared and left alone. Install went well after that, but windows absolutely refused to cooperate and run stable no matter what I did.
the second time around... it went nuts on the audigy 2 setup am i reading that right? and yea via sux donkey nuts i use alot of amd stuff.. but i've kept it nvidia chipsets
the latest bios is 1009, so you might wana do that
also IF the via board is like the nvidia one, you have one set of sata ports controled by via and oneset controled by a promise one, you might uhh wana flip between the two, and make sure you ahve the right driver for which set of ports its pluged into
also get the drivers from asus instead of via.. sometimes they are diffrent... man im tired hope im not repeating myself uhh im asuming your installing the 4 in 1 drivers 1st after initial install
The system freaked many times before the Audigy 2 was even installed.
Yes, I got the newest drivers from ASUS's website for the Via SATA also with no effect. And the newest 4in1's were the first thing installed once Windows actually got up.
Bios 1009 was still in beta so I didn't wanna chance a beta BIOS and now its to late, the mobo is already snapped in half and thrown in the trash since I can't return it for refund.
what were you doing when it crashed or was it just freaking out after bootup
what im getting at is, to me it sounds like maybie the sata is fucking up? did you try running it on the promise ports set instead of the via one? there should be 2 sets of physical sata plug ins
I was attempting to do Windows updates is when the screw ups started to happen but anything in general made it pissed off. When I had my older WD PATA drives in, the entire system rebooted itself continually.
I heard ugly things about Promise's SATA chips not to mention the data transfer rates from a comparison standpoint, sucked so I decided not to even bother with them.
could also be a heat problem
you sure you had the heatsink mounted right? only time i've ever had my system reset constantly was when i hadn't clamped a heatsink down (if it wasn't like the same error over and over agian)
Heatsink was perfect, I was using a brand new Zalman 7000alcu with AS5 so that worry didn't even cross my mind.
i did have one system reboot constantly.. but i just can't remember what it was that caused it... what video card u using?
did it reboot or just shutoff?, did it bring up an error beforehand or just do it?
Nope it just reboot with no error. By that time, I knew something was wrong so I only had to witness it a few times before I decided to wiped everything and started over.
the only time i've ever had windows xp actualy BSOD was from my video card or heat, except onetime when i had just a bad install and redoing it fixed it
just for shit and giggles toward the last few installs did it ever crash before you installed the video drivers? also you have another video card lieing around of say the oposing company? i have a broken 9800 pro that would reset my computer randomly... i still use it but i put watercooling and seemed to fix it .. sort of
Video card was fine, ran overclocked on my Intel setup no problem and it has a NV5 with AS5 on it.
Trust me, heat wasn't a factor in my problem.
uhh you might want to re think that i get diffrent overclocking on my video cards based on what mb its plugged into.. i think the voltage the mb actualy supplies to the card varies or something, and you might of nudge the heatsink in transfer or maybie the mb is overvolting it and making it run hottter? i get an extra 50mhz on my 9800pro in an nf7 then i do in my a7n8x i know your frustrated but only way your going to figure it out, if you still want to , is try narrow it down as mutch as possible.. if you have just an old shity graphix card throw it in and try it, dont install the drivers for it and just run super pi and see what happense, if you set it up with audigy 2 in it every time.. try setting it up without it in the computer, rip out anything extra, try reseating the heatsink even if you think its perfect just try it. try using only one stick of ram, in diffrent slots i know it shouldn't matter.. but sometimes it does with abit 754 board we had to put one stick on slot 3 to install xp and then added the other stick to slot one after full setup and it worked, anyother way windows install got currupted
oh and i dont blame abit i blame via cuz .. i've never had real install problems (non user related) with nvidia chipsets and i have with via.. maybie its luck maybie its not but shrug
look I will tell you what is wrong!!!!!! get a new PSU...... get the biggest one you can find and dont say its not the psu because it is!!!!! there is nothing wrong with VIA chipsets and trust me asus wouldnt sell it if there was... anyway i had a similar problem just last week installing an N-force3 in my aunts comp... i had no problems after i switched to a larger PSU(NAME BRAND!!!!) as a matter of fact i had the same problem with my Athlon xp, Untill i got a good POWER SUPPLY. Antec true power 430 or 550watt... if you want a really good one try pc power and cooling. please tell me you kidding about snapping the board in half!!!
i set up raid 0 for my boss on monday!! he has the same board that you do and he put the computer together all by himself, installed windows and all that good jaz.. trust me he hasnt built one since a 486 according to his wife!!! next time this happens check for PSU problems and i have even had a faulty cd-rom drive give me similar problems.... dont just go breaking stuff in two......
Yo, BallerX....perhaps decaf would be in order.... ;)
Anyway, I was also curious as to what PSU you were using. It is possible you have a defective board, it does happen now and again. If so, I'm sorry that one board had to ruin your AMD experience, and hope you'll consider exchanging the board rather than returning it and trying again. However, it could be a power supply that isn't delivering the juice you need too, and the reboots you're having can definitely be a symptom of that.
We'd like to help...give us all the details and specs that you can, and we'll try.
My first thought was power supply too. Did you try a different hard drive? EIDE instead of SATA? Different ram slots? etc. It seems like you gave up pretty fast :p
My initial settup gave me a bitch of a time with installing SATA but is now very smooth. Also if you booted up the system for the first time with the Audigy in it that may have been the problem. You should first just set it up with a stick of ram, hd, cd basically whats necessary.
Also you could have made this thread before you sent it back, you would have probally found a fix from a member.
ur post was to long but it boggles my mind how u can blame asus lol did u even rma it or think something else was the problem??
i had to use the via sata drivers with it on the promise fast track
The PSU was a brand new Antec NeoPower. And I swapped between my older WD IDE drivers and SATA and still had problems on both ends.
Either way, I had no patience or desire to look deeper into the situation, what can be sent back, will. The rest will be thrown in the garbage where it belongs.
please give directions on how to get to your grabage. :p
Well, you gotta realize that there are bad boards out there and it's a fact that you are going to get one of em every now and then.
I had a few bad Nforce 2 ultra boards myself along the way until I got a good A7N8X Dlx and just recently I got two bad msi neo 2 boards in a row.
I got the A8V after the msi boards and everything was perfect from the get go. Once of the best motherboards I've had the pleasure of setting up.
what im talking about how can u talk shit about a high quality board even if its not ur favorite company they are up there
I read your initial post, then just skimmed through the replies. I didn't notice anyone mention this but... do you think your problem could be with your AMD 64 chip and not the mother board? These AMD 64's have built in memory controllers and this would seem a logical solution since you had a slight change of problems when you swapped out your memory module to a lower latency one.
I'm just re wetting my feet in the newer motherboards for I too am looking to upgrade. Perhaps my post is irrelevant and I don't know what I'm talking about, but it's just my 2 cents....
Good luck!
carry on...
IceWind said:
... Bios 1009 was still in beta so I didn't wanna chance a beta BIOS and now its to late, the mobo is already snapped in half and thrown in the trash since I can't return it for refund.
I'm sorry but i couldnt help laugh how casually you said you snapped that mofo in half. LOL :D
Believe me, after the stress this POS put me through, breaking it was the best stress relief.
I've had rather good luck with my A8V-Deluxe (picked it up about 2 weeks ago). I have not had any stability problems, OCing didn't really work until I tweaked the BIOS well.. so now I've landed at 2.7Ghz... hmm...
wow for a 3000? i have value ram and arent pushing as far as i can go so enough said :p
Translation...you lack the patience and tolerance required to be a good tech. Please turn in your tech card now, and rather than being upset with the AMD scene, consider that it could be you got one dud board out of a batch of good ones and that RMA-ing might have solved everything. Furthermore, it looks like your lack of patience led to you taking your temper out on a system board you could have RMA-ed successfully.
After working with multiple brands of boards for both Intel and AMD CPUs, even the best brands I've seen have a defect rate. You too, could get one of these on occasion. I've also seen situations (including those of my own) where because I didn't know something about a piece of hardware, I blamed the hardware or a defective part when there was just a setting or issue I needed to know about to get things running. It required patience.
What memory were you using? I had the same exact problems with a system I was building for a friend using a D865PERL. Switched it for another just like it. Same results. Exactly as you described. Switched out memory PSUs, CPU's drives and video cards. Tried a different case even. No dice. Changed out the board for a Asus P4C800 Deluxe. STILL NO DICE. So after some research I found the Mushkin PC2100 DDR I was trying to use from his old Athlon XP. I found out it and the Kingston Value Ram that I was using wasn't validated for the I865PE/I875P chipset.
So that could definatley be your problem. I had the same issues. Random reboots, Flaky OS. Intermitant crashes. All kinds of problems. I tested some Samsung DDR 400 ram that was on Intel's approved list of memory modules for the i865/i875 chipsets and it worked instantly. So we went out and got some Corsair XMS PC3200XL memory and it's been working ever since.
If your patient the solution will come to you.
