Asus A8V Deluxe Socket 939 K8 review
jhego
ASUS® A8V Deluxe - VIA K8T800 Pro Motherboard
Do any of you guys owns this mobo? I can't find any reviews for it...
I have this board,and a fx-53 and it rocks.I havent had one single problem.Very stable in my opinion.Also i would like to point out that i bought this board before any other 939 socket boards were out.Normally i preferr to wait for more brands to come out before making a decision,but i was due for an upgrade,and figured i would give it a try,and buy another board later when there out if i didnt like this board.Well i made a good choice because this board turned out to be great,and later got great reviews,and i got the board for $142 shipped,and curently the board went up in price to like $152-$170+ I havent seen it cheaper then what i payed,although now some online stores are offering farcry with purchace of mobo,cpu combo.But i already had farcry so was no concern of mine.
I too have the A8V with an FX-53 and outside of not being able to format my SATA drives with the Promise controller (VIA controller working great) and the AI Overclocking defaults as noted by DriverHeaven, the system has worked flawlessly. I don't normally overclock (with three systems, the room gets plenty warm) so after adjusting the AI Overclocking settings down per DriverHeaven, the temps almost match that of my SK8N/FX-51 system (albient better case temps from the Stacker case). Prime95 has been ran off and on overnight with normal 'puting tasks any other time. All in all, I'm very pleased with the system and will be more so when an 6800GT arrives.
Why cant you format your sata drives?I havent had any problem formatting my 2 sata raptors in raid 0.And im using the promise controller.
I'm not entirely sure why. WinXP would go through the process of formatting however it took an abnormal amount of time only to fail the format after waiting an hour. I ran SeaTools against the drives which seemed to point out cable problems but after swapping out both cables and SeaTools apparently saying everything was AOK, still no luck formatting. I tried Promise drivers from the CD and off the FTP site (raid drivers). No dice. After an hour of swapping and fidgeting, I moved the two drives to the VIA controller, created the array, told XP to partition and the format was quick. I'm still not entirely sure what the deal was. Perhaps some funky interaction between the Promise controller and the Seagate drives I chose. But the drives and VIA SATA are flying and the system has been running great so far.
Mine formatted just fine as well, I had a probelm once with having a set of drivers that was corrupted or the floppy disk had a problem, had to be one of those things unless the MOBO has a problem.
No it was probably corupted drivers.I read on some forum alot of people were having problems with a driver release asus had up.Also you might have been trying to use sata drivers instead of the raid driver or vise versa.I had the same problem with my floppy not copying the drivers over.Then i relized i was using the wrong drivers.
