ASUS A8V deluxe revision help
stavrosHz
I recently purchased the A8V deluxe mobo and was wondering what gives the right info as to what revision number it is.
It is meant to be a Rev 2 but every program like Sandra and Everest tell me its 1.x.x which is not what i bought (or thougt).
I know there is problems with the Rev 1.x.x boards and would like the right info just confused as to what is the correct info. It is printed on board Rev 2.
Look at what it says between the pci slots. I had the same thing and found out somewhere that all boards showed rev 1.xx in programs like cpu-z
