computergeek22
- Dec 2, 2005
Which ones a better choice for overclocking? THe Asus seemed to outperform the DFI in anandtech's review.
What kind of RAM are you using? I need to buy a processor and RAM to OC. I was thinking of an Operton 146 or 148 and some OCZ or corsair stuff. BTW are you gonna use an ATi card for crossfire?wizzackr
I just put together an A8R-MVP with an opteron 170. Cannot say too much, as I am currently tinkering around with overclocking and stuff. so far: 10x250, RAM@227MHz 3-3-3-8-T1, rock solid, will run prime and sandra burn-in over night and then see how much higher i'll get tomorrow.
Pretty nice board, really. Installation etc. went through like a charm, no problems whatsoever - and this is on the release BIOS. one thing: don't use SATA port 1 or 2 if you plan on some crazy overclocks, as I cannot load up windows due to HDD corruption if I go higher than 2700...
Hondaman4ever said:What kind of RAM are you using? I need to buy a processor and RAM to OC. I was thinking of an Operton 146 or 148 and some OCZ or corsair stuff. BTW are you gonna use an ATi card for crossfire?
