ASUS A8R-MVP memclock value problem??
MaxOut313
I have my full system running. ASUS A8R-MVP, AMD X2 4800+ rev. E6, and 2gbs of Corsair XMS DDR550. Im not overclocked right now, but when i look at my memory clock speed. Its 166Mhz (DDR333) instead of 200mhz(DDR400). What could be causing this? Anyone with this board have this problem also??
You might want to post something on the anandtech article A8R-MVP 325HTT by Ryan Norton. He currently has an A8R-MVP. You can ask him if he's had any such problems. He's also available on SPCR forums....
Also have you put a divider by mistake or has your board come with a divider by default if so you can just bump it up to 1:1 and should be okay....
nah i tried that. i have it running on 1:1. set it to 200mhz and still 166. i called asus and they said it could me corsairs problems. personally i think they are full of sh*t.
Who Asus or Corsair? Corsair memory, recently, hasn't been doing that well - problems w/DFI mobos. i'm not too experienced with this, but here's a bump from me anyway....
people are staying away from that board by the millions. try dfi street, or xtremesystems.org, amd forum.
good luck.
