ASUS A8R-32 MVP question
underdone
I just bougt an ASUS A8R-32 MVP deluxe, and i have a question. Do i need drivers for the chipset? And if i do where do i get them i've looked through the ati and asus website and i can't seem to find them.
you don't need drivers for the northbridge, only for the southbridge. drivers for the northbridge are already built in so you don't need to install anything for it.
Aiya is right but I'd like to add a couple things. You only need the southbridge drivers if you are going to use its functions (Raid array). The board worked for me just fine with plug and play drives on the sata port no problem. But you definitely need to update the bios to 0303, 0404, or 0505. I don't know if it is still shipping with the original 0211 bios, but its was crap.
Wow, that's nice to know i'm so used to using nvidia based boards, its just one less thing to do at install.
yes, that is correct. i installed mine because i wanted to know if my hdd was running at SATAII speeds. i too, had it running for while before i installed them so you'll be fine. also i bought my board 4 months ago and it had the 0311 bios and have since flashed to 0404.
