Problem # 1
Reinstalled the OS this weekend and I noticed that the harddrives are looking like they are hooked up like USB/Safe to remove hardware.
When you look down at the systems tray you see the icon safe to remove hardwares which shows the three drives that are hooked up to the SATA ports.
The harddrives show up in Window XP find as harddrives
Has this always been this way and I haven't noticed it or is something not right
Problem # 2
When I shut down Windows XP
It seems that everything shuts down but the computer doesn't power down
Problem # 3
Does the EZ power plug need to be installed if the following Video cards have power plug to them
System Spec
Asus A8N32-SLI
AMD 4400 Stock
Arctic Cooling 64
2Gig's of OCZ
Creative Sound Blaster Audigy 4
BFG 7950 and EVGA 7950
74GB Western Digital Raptor
2 X 250 Western Digital
Silverstone 750W powersupply
Problem # 1
Problem # 2
Problem # 3
System Spec
Asus A8N32-SLI
AMD 4400 Stock
Arctic Cooling 64
2Gig's of OCZ
