Asus A8N32-SLI Deluxe PSU Problem
Hi all, I just picked up the A8N32-SLI Deluxe mobo (http://www.newegg.com/Product/Product.asp?Item=N82E16813131568) for Christmas and upon getting it situated in my case, realized that there seemed to be a serious problem with the 24pin psu slot on it. I bought the ASPIRE ATX-AS500-SV 12V 500W psu sometime last year (http://www.newegg.com/Product/Product.asp?Item=N82E16817148005)
and it's a 20+4 pin PSU. It worked great on my last motherboard, which only had a 20pin EATXPWR slot, but the A8N32 has a 24pin slot for this psu attachment. Is there any way that this power supply can be compatible with this motherboard, or am I going to have to spring for a new power supply in order to get this up and running?
In a nutshell, will a 20+4 pin psu work with the A8N32 24pin motherboard? Thanks!
Ah ha! Solved my own problem. Just in case anyone else runs into the same issue...the A8N32 has an extra 4pin molex slot right adjacent to the 24pin slot. If you have a 20+4 pin psu, you simply plug the 20pin piece into the 24 slot in the only way it allows you to, and attach a separate 4 pin molex piece to the adjacent slot. Fairly self-explanatory I suppose...a little clarification in the manual might have been nice.
You aren't doing that nice board justice with that power supply IMO. The A8N32 has three important power connections to the board: The main 24pin, the Aux 4pin, and the 4pin molex for the video cards in SLI. Even if not running two cards I always plug that in when doing builds. The nicer higherend PSUs will have a detachable 4pin off the main connector for more compatibility with more boards. This is NOT to be used in the Auxillary 4pin socket located elsewhere on any board. (Toonage can just see the rush of RMAs coming in to manufacturers after overexcited noobs ruin their new Christmas presents)
I understand that obviously this is a sort of ghetto fix-it I did in order to get the thing up and running, but everything has been running fine and stable with the PSU and motherboard set up this way. Could it end up ruining my system, or are the cons more in the way of performance decreases? Obviously I plan on upgrading my PSU, but I don't have the immediate cash to do so. I do plan on going SLI with my 7800GT, however, and I suppose I will absolutely need to upgrade to the proper PSU before doing so.
I have my A8N32 running the same way with an ultra-xconnect 500psu. I dont think its a "ghetto" way of running it, because if they didnt want it to work with a 20pin psu they would have key'ed the plug differently.
sweet, i have the same PSU and was wondering if it would work ok. I got my x-connect last year, before i found out i wasnt going to be able to upgrade for lack of funds. its been sitting in the case i bought at the same time in a box hehe. i did however get the 24 pin cable for it. i just love how it looks.
