ASUS A8N-VM CSM woes...
VanFanel89
Hi all,
I have this motherboard in my sister's system with a dual core Athlon 3800+. I am using onboard video, two hard drives, two optical drives, 1.5 GB of OCZ ram and a 430 watt ThermalTake PSU... it's a nice little system.
The ONLY thing that is pissing me off is the CnQ drivers with this motherboard. I tried three known working processors and all of them, when CnQ is enabled, cause the screen to jump a ghost image when something that causes load to happen. The main image would stay normal but suddenly you'd see mirror images just flashing in and out. I tried different versions of the drivers to no avail. With CnQ disabled - all is well, but the procs run at like 43C with the copper HSF :eek:
Can this be caused by the onboard video?
Freaky...Is the CPU voltage correctly set? It should be around 1.3/1.35 unless you have an EE version.
It is a quirky problem: do you have the CnQ drivers installed?
This guide looks helpful...
~Ibrahim~
~Ibrahim~
I tried it with 3 different processors (2 3800+ and an FX-60); I have access to many a-processor and i know this is not a CPU issue. I tried two different versions of the drivers...
edit: for reference - I work at AMD; I know all about the CnQ and their quirkiness.. this aint a processor problem :p
lol, cool, cool.
I've never heard of this happening, so peculiar. You wouldn't happen to have a discrete GPU laying around that you could test?
I don't see at all how CnQ could effect the onboard video, which it apparently seems to be doing. Does this graphic problem happen constantly or intermittently?
~Ibrahim~
the drivers are the newest one; the BIOS is also the newest I THINK; i'll check tonight
I have that board in my upstairs PC running with an Athlon 64 3200 and 2x512meg memory. It's been flawless in the year or so I've had it. Some things to check:
- Is the BIOS the newest revision? (Some of the older revisions for this board were flaky)
- Set BIOS values back to defaults and see if the problem goes away
- Install the newest Nforce 430 chipset drivers installed from the Nvidia website.
- Install the newest GeForce graphics driver from the Nvidia website
- Check temperature and be sure the CPU is not too hot
- Are you running Vista? Vista has it's own C&Q built in in the form of power management profiles.
