ASUS A8N-VM-CSM on-Posting Issue
Wolfsbane2k
Hi.
System Specs:
AMD X2 3800+ S939
Asus A8n-VM-CSM board
2x 1GB Corsair VS400C3 DDR400 sticks.
Enermax 535W EG565AX-VE(G) PSU
Palit 7600GT PCIe
5x IDE drives
2x DVD writers.
I've had it best part of 6 months now, and everything, once booted, runs smoothly with the cpu clocked to 2.2GHz, memory locked to 200MHz at stock timings and voltages. Dropped HTT multiplier down to 3x for sanity.
It's been 3x prime95 stable for 24 hours and a 24 hour memtest stable, so I'm pretty damn sure i'm not stressing anything unnecessarily.
However, the box has never been able to post if the restart button is pressed, and i have no idea why - it boots up every time I press the on button, but a reboot either from windows, bios or the front button, does nothing but fail to boot.
Now it's annoying me as i want to stick this box into a corner and let it become the server it was meant to be.
Temps are ok, - in Bios, cpu is 50*C system is 32*C. in windows, GPU is 52*C.
I can't work it out. Anybody got any ideas?
Thanks in advance!
Everest home dump:
Field Value
Sensor Properties
Sensor Type Winbond W83647HF (ISA 290h)
GPU Sensor Type Driver (NV-DRV)
Temperatures
Motherboard 44 °C (111 °F)
CPU 53 °C (127 °F)
Aux 53 °C (127 °F)
GPU 53 °C (127 °F)
Maxtor 6L250R0 36 °C (97 °F)
Maxtor 6L300R0 36 °C (97 °F)
SAMSUNG SP2504C 31 °C (88 °F)
Cooling Fans
CPU 1722 RPM
Power Supply 2009 RPM
Voltage Values
CPU Core 1.16 V
Aux 3.71 V
+3.3 V 3.30 V
+5 V 5.54 V
-12 V 1.79 V
-5 V 2.54 V
+5 V Standby 5.02 V
VBAT Battery 2.24 V
Debug Info F C4 FF A8
Debug Info T 44 53 53
Debug Info V AC E8 CE CE FF CB CC (03)
Edit: for some reason Everest didn't pick up the +12V
Speedfan detects it as 12.31V.
Quick Bump.. .any ideas?
I've been fiddling with the bios settings, and box won't even reboot on default settings with only a SATA drive plugged into it :/
Cheers!
It is possible that the motherboard just doesn't like the overclocking; boot issues often result from overclocking. Did it do this when running at stock?
Also, have you tested it with another power supply (software voltage readings are almost completely useless) or a multimeter?
Multimeter checks:
from ATX connector @ load :
+3.3 = 3.34
+5 = +5.14
+12 = 12.15
idle:
No change.
Molex:
+12v rail 1 = 12.15
+12v rail 2 = 12.05.
+5v = +5.13
It appears that there is a repeating issue for soft reboots on old asus boards, having giggled the net for a bit!
Well everything certainly looks good on the voltage front. In that case I would definitely assume it's the motherboard, as you said with soft reboot problem. If it bugs you too much you could try it at stock and see if you have the same issue, but I would have thought that overclocking>irritating reboot process :D
That's what i thought as well.
Just aquired a new bios update for it, left it at default settings, and it still didn't boot - so it's not overclocking that's causing issues.
Back to the support queue!
