I fail to see where the problem is...gotkilled said:
Weiman said:bboy: Which board, the Asus or the Gigabyte?
bboy said:Why the ASUS A8N-VM CSM of course!![]()
ALYNCH75 said:Is there that much of a difference ...C use. It is also a little faster in general.
ALYNCH75 said:Is there that much of a difference between the 6100/430 combo and the 6150/430 combo chipsets
Look for yourself. Here, I am stealing Jelic's review:ALYNCH75 said:How good are the onboard graphics on a scale of 1 to 10 for gaming
veeoo said:Where did you buy the a8n-vm csm from? I've been waiting 3 weeks to get this board. I cannot find it in stock anywhere.
mikeblas said:Are those chipsets being recalled?
http://www.theinquirer.net/?article=27129
ALYNCH75 said:Hey I have just received that Asus board that everyone is waiting for. Its a piece of junk. I mean the board is okay but its really picky about memory.
ALYNCH75 said:I first used some Corsair memory pc 3200 ddr and it kept giving random errors now it is working fine. You will have to set it to auto configure to get your base settings then you can change them. So it was my mistake the chipset is fine. It was my fault by not setting memory paramers in the bios. I will tell you this...... if you dont' have a floppy drive you will have to find a work around in order to boot from the sata.
Thanks for the links!gerick said:
