ASUS A8N SLI Premium
dante2010
What is the difference between the two lan ports on this MB?
I am using the Marvell Yukon one, but I'd like to know if there is a difference between them.
O, and after I installed the latest chipset drivers, another lan controller was activated (making a grand total of 3!) It comes up as "NVIDIA nForce Networking Controller".
There shouldn't be 3 of them. I don't think there is much difference. I would think the Nvidia one would be slightly faster depending on how Asus implemented the second GbE. If it is on the PCI bus, it will be slower, but if it's PCIe, it might not be that much different. Last time I looked (Deluxe version), Asus used the PCI bus. Only MSI used the PCIe bus for the 2nd GbE.
Well there isn't 3 physical ports. I do have 3 lan connections when I look at my network connections tho.
One of them might be the Firewire port. Sometimes happens if i remember correctly. What does it say under the device manager?
