#1 question. My fans go right on when I hit the start button and stay on ,Try reinstalling the BIOS. I using the 1302 beta version of ASUS BIOS.
#2 My northbridge run around 40c at idle,goes to 45/48c when gaming, I am running two 7800GT,I can not even see the northbridge. I read somewhere that it is not good to run this board upside down because of the cool pipe for the northbridge does not work right, but your temp are not much higher then mine.
I had no more problem with this board since I got my replacement board back in Aug, it a good board,I just wish I could get a higher CPU voltage in the BIOS so I could overclock my CPU some more.
From what i heard around the board, for some reason there have been many RMA's especially on the A8n-sli Deluxe board. I dont know why.
ok buntz, how come alot of peeps are having problems with this board, did asus make a bad bunch of them or something, or is it the hardware that people use. its werid man, cause like i said before, mine hasnt had one problem from day one. maybe i was one of the lucky ones, . i bought mine off of newegg, anyone else buys theres from there? for the ones that are having problems, i hope everyone gets them fixed, cause i fine this a really good board.
my future upgrades are going to be to the 4800+, 2gbs of ram 2x1gb sticks, and two 7900gs BFG cards. oh and a bigger PSU, 550watts is ok, but i think ill need more, for the extra power needed for the vid cards. good luck everyone.
One of my friends has the Premium version he got from Ebay and it works for the year and a half he's had it. I have the Deluxe and its been a PIA for the 2 years I've used it.
Thank goodness for this thread. After 1 RMA, I thought my A8N-SLI would be fixed. Apparently the Bios is now giving me the 1-2-2 beep code which stands for BAD MOBO! I'm debating to replace it forever or RMA it...AGAIN. Any advice guys? (Bangs Head)
I'm sorry, but anyone that has to rma the deluxe 6 times is a fool
and please don't tell me you're another one of the guys RMAing it for the chipset fan...oh please..
they probably are, but i just did a google for award bios post codes and thats the first link i picked. its pretty sad when abit has come up with the little lcd screen on their mobos that displays a code on boot-up and why no other motherboard maker has thought of using that idea. i think its real easy, if they will use the same post codes as abit everyone will not have to remember the old post beep codes. i mean there are times i cant remember them all and im into the old vintage systems, ive still got an old pentium 120mhz still running and its runs stronge on win98se.
