My A8N-SLI has an incredibly frustrating problem. I have successfully set my A643200+ to run at 250FSB and 2.5GHz confirmed by the BIOS and by CPUZ and it is stable after 12 hours of simultaneous Prime95 torture test and CPUburn. I have set my memory to run at DDR500 speeds and it ran just fine as confirmed by CPUZ. What I cannot do is set my CPU and memory to run at those speeds together. Instead, whenever I get my memory to run at DDR500 the motherboard underclocks my CPU to 1.75GHz (yeah, that's arbitrary and weird) and whenever I overclock my CPU the BIOS sets my memory to run at DDR266 (and this is dynamic, not a fixed ratio, it adjusts the divider to make it run as near to DDR266 as it can no matter what FSB I set it too). The problem is that to overclock I have to set the JumperFree Configuration settings in the BIOS to manual and it automatically sets the DRAM Configuration settings in the CPU Configuration menu to auto and whenever I set the DRAM Configuration to manual it sets the JumperFree Configuration settings to auto and so I can't manually control both the CPU and the RAM frequencies and timings. I am running BIOS 1008. Anyone who has any similar experience or advice to offer, it'll be really appreciated.
