asus a8n-sli issue
demons9872
i got this board off these forums but the nforce 4 hsk and fan are pissing me off first the hsk is hot as hell and this dam fan is making a grinding noise what would be a good aftermarket cooler to get for it but cant me to big because im gonna be running 2 7800gtx within the next month or so
no ones knows of a good north bridge hsk forme any one know were i can get ahold of asus and try to get one of there replacement fans if they have them i tried there website but it wouldnt let me connect to it for some reason
had the same issue with mine you are having.
call this number if you are in US or Canada:
(510)739-3777, option 3. You need to have your Mobo S/N ready.
or you can email RMA@Asus.com
if you email, they ask you include your name, mailing address, daytime phone number, mobo model # and serial #. Put Northbridge Fan as the subject of the mail.
Temporarily till Asus ships me my replacment, I bought a Vantec VGA cooler kit that had a low profile, passive heatsink. I cleaned off the Chipset with some 91% iboprofil (i think that is how it's spelled) rubbing alcohol, and dried it with canned air and applied new arctic silver to the die, and then cut a hole in the thermal adhesive that came with it, and put the heatsink on it for now. I'm only getting temps of 44-46 Celsius, and that is ok short-term.
