Asus A8N-SLI DLX unknown hardware
I just put my system together:
3800x2
A8N-SLI Deluxe
2gb Corsair
eVGA 7800GT
200gb SATA HD
Plextor 716SA DVD Burner (SATA)
But in device manager I cant get rid of this "Unknown Device". All of my drivers are loaded (I thought). Any idea of what it could be? Both my NICs are installed as well as sound, USB, RAID and Firewire. I'm lost.
I have the Premium and I have the same thing. Doesn't seem to hurt anything but it is curious.
I had the same thing with the Deluxe. I formatted and reinstalled everything and that did the trick. Dunno what it was. Prob a driver that didnt install fully...
I had that very same thing when I first got into windows. After I install The chipset drivers (including IDE), Video drivers, and the SATA drivers, it went away. I know the SATA wasn't the Issue because it showed up as a raid card.
It has something to do with Asus AI booster. If you check the device ID it should be something like ATK0110. Take your Asus motherboard cd and look for a file called ATK0110.SYS (I think it's called that way). Did the trick for me. Or you can install the Asus AI software.
Hmm.. Almost forgot that I loaded it as well (not sure if it has any real use to me.) I think I may have done it because of the trouble I was having iwth the standard bios updater and I wanted to figure out if that would would work either (which it did).
mrgimble said:
Awesome help, I will try that out tonight.
Checked my A8N SLI Premium drivercd and you can find it in the folder: \Software\AiBooster\Acpi\WIN2000. There is a .INF file there that will install the driver if you update the driver with the Windows Device Manager.
There is a device driver for Win XP 64 too. It's in \Software\AiBooster\Acpi64\Win2000
