Hi, I am having some issues installing XP Pro SP2 with some new kit and I was wondering if anyone else has suffered the same. Here is what I purchased this week:
Asus A8N-SLi Deluxe nForce4 SLi Motherboard
AMD Athlon 64 X2 Dual Core 3800+
XFX GeForce 7800GT Extreme LED Edition 256MB GDDR3 VIVO TV-Out/Dual DVI
G.Skill 2GB DDR HS PC3200 (2x1GB) CAS2.5 Dual Channel Kit
Hiper Type R 580W PSU
The above is installed with 1 SATA HDD and 1 standard IDE HDD, floppy and a couple of cd/dvd roms. The only other old bit of hardware in there is an Audigy 1 PCI card.
Heres the problem: I boot off the XP cd, press F6 to load the nvidia driver (latest from NV site), load the driver and continue. When the installer gets to Setup Is Starting Windows it hangs. I suspect its the storage driver thats causing the problem but I have the latest from NV. BTW the SATA drive is plugged in to the nvidia connectors - the SI sata controller is disabled.
I done the google bit and its seems there are issues with a lot of people and these boards, but there are so many 'fixes' out there its hard to nail the right one without spending weeks doing trial and error.
So if anyone can be so kind as to enlighten me a little it would really be appreciated!
