ASUS A8N-SLI chipset temps
ruin97140
okay so ASUS sent me a new chipset cooler, I am looking at ASUS probe, is the MB temp the same as the chipset temp? if not, whats a good program to check? thanks
The newer revision 2 chipset fan from asus dies just like the old revision 1 so don't even bother with it would be my advice, mine was 6 weeks old and i just replaced it 2 days ago, it started making noise after a week, go figure.
I replaced it with a Vantec copper chipset cooler which works a treat :)
