Asus A8N SLI chipset failure.
Gabriel
My chip is dying. Do I absolutely have to remove the motherboard to replace only the fan (not heatsink). I really dont know how to take out the motehrboard and put everything back and it looks like i can reach it with the small screw driver to replace the fan. I asked monarch to send me a replacement but if they don't should i just call asus?
Thanks.
Call Asus I mean. I don't think Monarch is going to do much for you. If the board is under warranty, then Asus should send you a replacement fan, for the northbridge I suspect. It would really require for you to take the mb out of the case, to do the job the right way. Search the forums both here and at Anandtech for your board and fan failure, you'll see it's a common prob unfortunately. Godd luck and don't do more than your comfortable with. If you need help, have a friend come over and you'll at least have another set of eyes and hands.
My chipset fan died on me about six weeks ago. Asus will send you a new fan that is configured to sit at a 45 degree angle as oppossed to the old fan which sits perpendicular to the bottom of the motherboard. To replace it correctly I had to remove the motherboard to get at the fan pegs that went through to the back of the motherboard. Once you remove the pegs the old fan comes off pretty easy. Give a little twist and it should fall off in your hand. Just remember to take the paste or thermal pad residue off the chipset before putting the new fan on. Oh, and the new fan comes with a thermal pad already attached. At least mine did.
Board is A8N DLX
Just get a 40mm fan and screw it into the heatsink that is already on it. I got my fan for $6.00 at Microcenter. Just take off the existing fan but leave the heatsink in place.
Yea, do that! Cheap effective and it wont die again. When i had my Abit Max II they chipset fan started to die and man did it make the scariest noise ever... These little chipset fans are prone to die.
BE careful though if you do that, if you add an extra fan and you have a long PCB for the video care youll have problems
I would just get a passive chipset cooler. Those damned little fans just suck ass.
Get both! Swiftech has a good heatsink w/ fan.
Well monarch is already sending me a replacement. I don't feel comfortable removing mobo though. I don't knwo what im going to do since sending them my computer is not really an option.
